Compression Test Signal Graph
Postby Jabsam » Tue May 10, 2011 12:05 pm
Hi all,
I right-click the compression bar graph,and select the "Signal" to bring up a Signal Graph.Could you tell me what is the meaning of the Signal Graph ? Thanks in advance !
Jabsam
Re: Compression Test Signal Graph
Postby Brian Haley » Tue May 10, 2011 6:06 pm
Hi Jabsam,
From what I understand, the bumps represent the acceleration of engine RPM for each cylinder firing event.
You could use a sync probe or secondary lead on channel B as a reference point to help narrow down the faulty cylinder as shown here.
Brian Haley
Autonerdz.com
Brian Haley
Postby Jabsam » Wed May 11, 2011 3:11 am
Brian Haley wrote:You could use a sync probe or secondary lead on channel B as a reference point to help narrow down the faulty cylinder as shown here.
Thanks,Brian。It help me much.Cheers
Jabsam
Postby Gary20202 » Sat Jan 31, 2015 4:26 am
How do you connect the sync probe, I have tried and never see the sync signal on the channel B. Obviously I am missing something in my setup.
Thanks for any help.
Gary
Gary20202
Return to PicoDiagnostics software
