Automotive kit test leads ?
Post by Robski » Fri Jan 28, 2011 3:51 pm
Can anybody tell me the input impedence of the four test leads that come with a four channel kit please ?
Thanks .
Re: Automotive kit test leads ?
Post by Robski » Fri Jan 28, 2011 6:25 pm
just to add i could do with knowing this over the weekend.
Post by Alan » Wed Feb 02, 2011 7:20 pm
The input impedance of the PicoScope, is (like all scopes) 1 Mega ohm.
The standard test leads are well, just leads (ie just low impedance wire / shielded co-ax cable). When plugged in to the scope the impedance at the tips of the leads will be that of the scope - ie 1 M ohm.
Post by Robski » Wed Feb 02, 2011 8:19 pm
alan
thank you for the reply that was the info i was after,however it was for the use of a Blue-point CTB & i saw this in the instructions as a warning.
Does not matter now as i have sent it back as it was faulty & ordered one from yourselves :wink:
Rob.
