pp218 dc current probe
Post by Richard » Tue Jan 27, 2004 7:35 pm
What is the frequency response of the pp218 dc current probe?
Will the pp218 show any current pulses that are in the negative direction?
Post by Autonerdz » Wed Jan 28, 2004 6:56 am
Hi Richard,
I am not sure of the frequency response specs, but it is a fine amp probe and will readily show anything you need to see in automotive. Comparing it to a probe costing four times as much, I can see no difference in response or resolution. The ONLY difference is that it may not be quite as well shielded as the expensive one. Not a big issue.
Yes, it will show current in both directions as long as you range it correctly in PicoScope, so you have the scaling you need.
:shock:
