R6 Starts With Error And Does Not Run
bgarforth
Post by bgarforth » Sat Sep 18, 2010 4:15 pm
I have a model 3223 model automotive scope and I'm attempting to use the latest R6 version of the PicoTech software. After installation I receive an error on startup of the application:
"The built-in custom probes library could not be loaded"
The application closes after acknowleding the error. I've tried installing the previous R6 version but receive the same results. R5 works fine.
Also, when starting up Pico Diagnostics I receive an error "There was a problem with the driver".
Any help would be appreciated. I'd like to use the new version and also Pico Diagnostics
Re: R6 Starts With Error And Does Not Run
Post by Autonerdz » Sat Sep 18, 2010 4:36 pm
bgarforth,
On some PCs, the 6.4.64 installer goes awry and does not properly update an existing installation.
Uninstall 6.4.64 and then install your previous version. Then uninstall your old version. Follow this with another install of 6.4.64. This usually takes care of the problem.
_________________
http://www.autonerdz.com
skype: autonerdz
In North America
bgarforth
Post by bgarforth » Tue Sep 21, 2010 5:21 pm
thanks for your help. I was able to install it under a different user name on my machine and it is working fine. There most likely is something running that is incompatible with the Pico software which I'm able to get around w/ the alternate user.
I'm running Windows XP SP3.
