Incorrect Calculations?
rod_au
Post by rod_au » Sun Aug 08, 2010 10:25 pm
I have used this program a lot since purchasing the 4423 Pico.
It has always provided pretty accurate data as far as I could tell in the past as I don't normally do mechanical test to compare the results.
However, the last two releases have been giving me very suspect results. I attached an example of a test made 2 weeks back with the latest software. This morning I installed the older 1.2.1 alongside the new version and opened the same file in both versions of pico diagnostics and you can see clearly that there is something a little askew with the new version. With a mechanical test this vehicle had even compression with a less than 5% variation.
I thought I would bring this to your attention although I am sure you are already aware of the issue.
In the meantime I will resort to the old version, with anticipation of the new release :)
Rod
Old Pico Diagnostics
New Pico Diagnostics
rod_au
Re: Incorrect Calculations?
Post by rod_au » Mon Aug 09, 2010 6:15 am
Ok, last one.
I tried the two versions again this time with a different file just to confirm the results.
Im done now :)
ziko
Post by ziko » Wed Aug 11, 2010 3:32 pm
Hi can you send the files please to support@picotech.com and put on the subject for the attention of Ziko, would be interested in analysing the data.
Ziko
Technical Specialist
