how to analyse my lambda sensor waveform ?
eric989
Post by eric989 » Wed Jun 02, 2010 5:54 am
Dear all,
These days, I tested two cars' lambda sensor,all are Zirconia Lambda sensor.
The waveform is very strange, at least for me.I know little about lambda sensor. :lol: There are a lot of vertical lines upon the traces.And the traces are very big/wide.
Could you tell me that what the traces meaning ? Is there any fault in the sensors or I make a wrong Picoscope software setting ?
I enclosed the waveform files for you. Many thanks .
chevrolet lambda.psd
chevrolet lambda
(499.79 KiB) Downloaded 590 times
toyota lambda.psd
toyota lambda
(255.85 KiB) Downloaded 468 times
Eric Chen
Hongke Technology,China
NigeC
Re: how to analyse my lambda sensor waveform ?
Post by NigeC » Wed Jun 02, 2010 7:26 am
Hi Eric,
Change your collection time to 1s/div or 2s/div as a start then increase to fast idle and back to idle to see it reacting to changes in oxygen. :wink:
It is working :)
Nige
Nigeiometric efficiency = 14 wrong : 1 right....
Post by Autonerdz » Wed Jun 02, 2010 1:54 pm
Eric,
The O2s in your captures are working fine. The reason you have a fat trace with all the vertical lines is noise from ignition events etc. Filter the signal to shave all that hair off for a cleaner signal.
Just curious...why are you using PicoScope 5? Looks like you did this with a 3000 series scope? PicoScope 5 cannot make full use of the capabilities of that scope. PicoScope 6 will.
_________________
http://www.autonerdz.com
skype: autonerdz
In North America
eric989
Post by eric989 » Thu Jun 03, 2010 5:40 am
NigeC wrote:Hi Eric,
It is working :)
Nige
Change the time base, Ok. Thanks, Nige.
Eric
Eric Chen
eric989
Post by eric989 » Thu Jun 03, 2010 6:23 am
Autonerdz wrote:Eric,
_________________
skype: autonerdz
In North America
Hi Tom,
About "Filter the signal to shave all that hair off for a cleaner signal." Yon mean activate Lowpass Filtering ?
I am always using PicoSope 6, not PicoScope 5. The chevrolet lambda.psd file I captured with 3423. The toyota lambda.psd file I captured with 4223.
It is interesting that I can filter the signal of toyota lambda.psd file, but can't filter the signal of chevrolet lambda.psd. I thought the filter function is within the software, have no relationship with the hardware.
Many thanks,
Eric
filter toyota lambda.psd
It is "toyota lambda.psd" I posted before, but I activate the Lowpass Filtering now.
(254.37 KiB) Downloaded 391 times
Eric Chen
Post by Autonerdz » Thu Jun 03, 2010 2:12 pm
Much better, Eric :D
The reason I thought you were using Pico 5 is because psd is a Pico 5 extension. Pico 6 saves psdata file extensions. I see now they appear to be psdata files renamed to psd. I'm easily confused :?
_________________
skype: autonerdz
In North America
Dave Hill
Post by Dave Hill » Thu Jun 03, 2010 9:46 pm
Why would the files need to be "re named"?
This all looks a little "dodgy" I think?
Pico 6 saves with a *.psdata file extension, whereas Pico 5 saved with the *.psd format. Whats going on?
eric989
Post by eric989 » Fri Jun 04, 2010 1:09 am
Dave Hill wrote:Why would the files need to be "re named"?
Hi Dave,
Why I rename psdata to psd, it is because that "The extension psdata is not allowed" in this forum.
regards ,
Eric
Eric Chen
Peter704070
Post by Peter704070 » Fri Jun 04, 2010 7:40 am
Hello
I use a Mac on a daily basis and cannot open PSD files, could someone place the scope patterns on the forum in a different format.
Sorry to be a pain but very interested in seeing the scope patterns.
Thanks Pete
Dave Hill
Post by Dave Hill » Sat Jun 05, 2010 5:32 pm
Hi Peter
I have the same problem when I browse on an iphone or ipad. I don't know if there is an "app for that" yet?
Often people post their waveforms in a common image format. A *.gif is ideal.
Eric
Sorry for my scepticism. I didn't know that the psdata file type was not accepted for upload. Weird that isn't it!
As Nigel has suggested, its a good idea to have a lot more time on screen than you have selected. The Automotive pre sets are a little dated now. The newer software & hardware allow you capture massive amounts of data & the superb zoom facilities mean that you can analyse any part of your capture with ease.
As for the noisy signal, I wouldn't be too concerned about it. Yes it can be filtered out, but in reality you can see the trend & you still have the ability to see the detail needed to draw your conclusions. Don't forget to "challenge" the sensor when scoping. Snap throttle tests can reveal a lot! :wink:
Cheers all
Dave
