COP probe
remmington
COP probe
Post by remmington » Mon May 31, 2010 8:36 am
hi... any clues on the manual settings for using this probe, just bought one, but have a non-automotive pico scope, without preset settings.
p@remmington.plus.com
PeterF
Re: COP probe
Post by PeterF » Tue Jun 01, 2010 2:20 pm
The output signal is quite small, use your most sensitive voltage range first. Use 1mS/div for the time setting as a start.
PeterF.
Re: COP probe
Post by Autonerdz » Tue Jun 01, 2010 3:22 pm
One other thing....The signal is going to be upside down as the firing is negative. You could use a math channel to invert it or simply create the custom probe for it that will invert it for you.
I would use more screen time at first with no trigger until you can see what you are working with. Then adjust to suit your viewing pleasure 8)
_________________
http://www.autonerdz.com
skype: autonerdz
In North America
