O2 sensor
PeterM
O2 sensor
Post by PeterM » Sun Apr 18, 2010 12:13 pm
Appreciate if you could tell me exactly how you would check the response time for a zirconia O2 sensor.
Thanks Peter
Re: O2 sensor
Post by Autonerdz » Sun Apr 18, 2010 2:19 pm
Pater,
You would first make sure the sensor is fully warmed up. Then let the engine idle until O2 is cycling. Then perform a WOT snap throttle. The initial gulp of air will drive the O2 max lean and then the accel fuel dump will drive it max rich. The lean level should be <100mv and the max level >800mv. 80% or so of the lean to rich switch here should occur in <100ms.
This only means that the O2 is OK at the time of testing. Intermittent issues are common.
_________________
http://www.autonerdz.com
skype: autonerdz
In North America
shay
Re: O2 sensor
Post by shay » Thu Aug 19, 2010 3:35 pm
shay
