Examining Chrysler 3.3 Engines For Broken Flex Plates.
Re: Examining Chrysler 3.3 Engines For Broken Flex Plates.
Post by Autonerdz » Wed May 23, 2012 9:03 pm
It was brought to my attention that the images in this post vanished. This post was done in the early days of these boards when images could not be uploaded. They were links to an old server we no longer have. I was going to edit the original post and insert the new links so it would just be fixed but was not able to do that. So....here are the missing images reposted.
Broken flywheel
Good CKP/CMP relationship 10x zoom
hakim
Post by hakim » Sun Nov 18, 2012 6:59 am
i have a 2002 grand caravan flex fuel seems like it has the same problem like yours when it gets hot after running for 15min start messfiring and backcfire and if it get too hot it will stall ,it it cool down for 15 20 min it will run again normally the code reader showed up po300,po303 po306 , one mecanic sugested me to change the coil pack changed it still same then told me to change injectors cylinder 3 and 6 i havent done it yet should i try first the cranckshaft let me know please thanks for any help????
Post by Autonerdz » Mon Nov 19, 2012 2:40 pm
Hakim,
I would monitor the crank and cam signals along with ignition coil current and injection if you have the four channel scope. Anytime you have a Chrysler with disrupted ignition and/or injection, the cam and crank inputs are a suspect.
