common rail injector question
Guest
Post by Guest » Mon Feb 02, 2009 7:26 am
hi
Is ther a reason why there is no preset setting in the automotive drop down tab for common rail injector voltage (only current) compared to petrol injectors which list voltage and current. Hope someone can answer my question
Matt Fanslow
Post by Matt Fanslow » Tue Feb 03, 2009 5:39 pm
I suspect the reasoning has a lot to do with the wide variety of strategies used to actuate the injector(s). Some operate on 5 volts, others over 100.
HTH. Later, Matt.
