BMW E46 330D 03 reg AMS
Postby Guest » Tue Sep 09, 2008 7:40 pm
Trying to scope air mass sensor on the above bmw, it has 4 pins plug but when i go to do the usual snap throttle test i've got no 1v siganl wire. All i can find is a square wave signal that increases in frequency under higer revs. Does anyone know how to test/ fault find on this system?
Many thanks
Guest
Postby Guest » Tue Sep 09, 2008 8:43 pm
Besides just looking at the pulse-train for basic signal integrity, my suggestion would require a known good example or specification. Basically, capture a pattern with it flowing as much air as it can, set up a measurement and look at max frequency. Compare to known good or spec.
It would also help to know why you are at the MAF anyway.
HTH. Later, Matt.
Guest
