Ford Transit/2002/2.4 Rough Running/No Power
s4c
Post by s4c » Wed Jun 25, 2008 8:16 am
Hi this is a scope of a crank and pump output signal. can anyone tell me if it is the correct signal or is the pump timming 'floating' around?
I suspect the pump being faulty or the cam chain is slack. Please check out the download
(198.91 KiB) Downloaded 261 times
PeterF
Post by PeterF » Wed Jun 25, 2008 2:03 pm
I think you are looking in the wrong area, the two signals are not related at all apart from being about the same frequency, it is the injection pulses that should be related to the cam sensor.
PeterF.
Matt Williams
Site Admin
Site Admin
Post by Matt Williams » Thu Jun 26, 2008 10:29 am
If you suspect a slack timing chain, perhaps comparing the cam and crank sensors may show some wandering in their relationship.
Matt
