Question: 2-Channel or 4-Channel Picoscope Automotive kit
boriordan
Post by boriordan » Sat May 31, 2008 6:03 pm
Hi all,
I would greatly appreciate some advise to help me choose between the 2-channel and 4-channel Picoscope Automotive kits.
As I am a complete beginner in the use of oscillopscopes for automotive testing, I have no idea if I would restrict myself by purchasing the 2-channel scope instead of the 4-channel.
If there are meaningful Automotive tests which need 4-channels, then I would choose for the 4-channel scope.
Any comments and thoughts gratefully appreciated.
Regards from the Netherlands,
Brian.
2 or 4 channel
Post by Autonerdz » Sun Jun 01, 2008 3:10 pm
Hi Brian,
You can get the job done with two channels. However, it may take a bit longer and there are some limitations.
If you were to add a Mixmaster ignition mixer for capturing waste spark secondary ignition, using a two channel, you would have to choose between splitting the banks by polarity between two channels or trigger. To split banks and trigger requires three channels.
http://www.autonerdz.com/mixmaster.htm
There is another example of when four channels can be handy in reply #7 of this thread on EDIS cam sensor syncronization:
http://www.autonerdz.com/cgi/yabb2/YaBB ... 1077376754
There are many other examples on The Autonerdz Community Forums and also a few more four channel example pictures here:
http://www.autonerdz.com/picoquad.htm
I would suggest the four channel, if you can afford it. It's more expensive to upgrade later.
skype: autonerdz
In North America
boriordan
Thanks for the advice Tom :)
Post by boriordan » Tue Jun 03, 2008 9:30 am
Hi Tom,
Thanks very much for your advice and pointers towards the AutoNerdz examples.
Very much appreciated, and especially to receive advice from such a renowned expert in this area. :)
Greetings from the Netherlands,
Brian.
Welcome
Post by Autonerdz » Wed Jun 04, 2008 2:43 pm
Brian,
You are welcome. I hope it was helpful.
No matter which way you go, you are making an excellent choice getting a PicoScope. These are the most powerful automotive scopes anywhere.
I got my expertise by making more mistakes than everyone else :?
Now we teach others how to avoid them. Guess the purpose of my life is to serve as a warning to others. :lol:
Now we have customers on six continents including a couple of your neighbors in The Netherlands. :shock:
