HDK sender
gordibg
HDK sender
Post by gordibg » Wed Feb 20, 2008 11:21 pm
Essential measurement in EDC diagnostics for old TDI and SDI engines is to check a >HDK< sensor. Green pattern is reference signal (never changes 10kHz approx. 3.5V at idle and no loads). White patern is measured signal 10kHz with variable amplitude and counter phase. Amplitude depends of injection qty. adjustment actuator actual position.
Regards from Serbia!
Passat AHU 1.9TDI HDK 1ch ref- 850rpm.psd
(39.1 KiB) Downloaded 563 times
