Common Rail hidropulsation waveform
gordibg
Post by gordibg »
Hallo! My name is Goran. A little present for forum members!
This waveform could be helpful in diesel injection diagnostics! I connected a piezoelectric sender near first cylinder injector approx. 10mm (first pattern) and second pattern is an injector voltage. Bosch CR, Fiat Marea JTD at idle.
Regards!
marea dizna i piezo.psd
(43.54 KiB) Downloaded 1159 times
LucaB
Re: Common Rail hidropulsation waveform
Post by LucaB »
Hello Gordibg, I can not see the files with that program open?
thanks
