immobilizer testing
Guest
immobilizer testing
Post by Guest » Sat Jul 14, 2007 6:39 am
is it possible to test an immobilizer signal to the ecu on a vauxhall astra 1.7 diesel
y17dt eng
year 2000
and if so what sort of waveform should it look like
thanks
PeterF
Post by PeterF » Thu Jul 19, 2007 1:13 pm
Unfortunately, this sort of signal will of necessity be difficult to decode. if it was easy it would not be much of an immobilizer! We have no specific information on the general form of the signal either. It could be similar to the 1 or 2 wire CAN Bus signals so you could look for signs of shorting to something else distorting the waveform but that is about all.
PeterF.
