Catalytic converter & Lambda sensor
Postby Charlie G » Mon Jun 26, 2006 4:55 pm
I have a new cruiser motorcycle with standard exhaust pipes which sound very soft. Apparently it has both a catalytic converter and also a Lambda Sensor. I want to fit slip-on straight-thru pipes on for a better sound. Do I need the converter and the sensor? The bike is fuel injected.
Charlie G
Postby Carl Grotti » Tue Jun 27, 2006 2:47 am
In the United States, removal or rendering an emission control device useless is illegal and considered "tampering". I'm not sure if this applies to you or not. (page 4)
Also, you need to keep the Lambda Sensor for fuel control feedback regardless of "off road use only" or not.
Carl Grotti
