location of camshaft positioning sensor on 2000 dodge neon
newfie 100
Post by newfie 100 » Thu May 04, 2006 1:08 pm
looking for the location of camshaft positioning sensor on a dodge neon. 2.0 l 16 valve engine
CMP
Post by Autonerdz » Thu May 04, 2006 4:27 pm
Should be at the rear of the cylinder head.
newfie 100
Post by newfie 100 » Fri May 05, 2006 4:43 am
is there anything special i have to do to replace one...can u tell me any tricks i need to know... thx for the response
CMP
Post by Autonerdz » Fri May 05, 2006 3:41 pm
No, not really. Just nuts and bolts. Did you confirm a failure with your scope?
Guest
location of camshaft on a 2000 dodge neon
Post by Guest » Tue Sep 15, 2009 2:46 am
:? I am having a problem with locating the postion where the camshaft is on a 2000 Dodge Neon[/i]
Carl Grotti
Post by Carl Grotti » Tue Sep 15, 2009 7:09 am
The single overhead camshaft is located in the cylinder head just below the rocker shafts. There should be a reference mark on the camshaft sprocket for alignment.
If you are trying to check to see if the camshaft is in the proper position in relation to the crankshaft, then do what Tom suggested and check it with your scope while monitoring CKP and CMP signals. If they are timed correctly, you saved yourself tear-down time.
Another technique used by some is the use of a pressure tranducer placed in the combustion chamber. Interpreting those results can be a challenge unless you're real famiiar with it.
