Could you take a look at this forum post
viewtopic.php?p=97581#p97581
This may help but would only provide you a momentary glimpse of engine speed at the end of the capture when using time frames of 200 ms/div or longer
However, if you stop the scope, your RPM math channel value will be displayed immediately
Alternatively you could try using the scope at 100 ms/div to see your RPM math channel displayed live, which sounds like this may be what is required
I hope this helps and please feedback for any clarification on the above
Take care.....Steve
