PicoScope 7 Automotive
Hi Steve,Steve Smith wrote: ↑Fri Aug 16, 2024 11:17 am Hi Martin, I hope you are well and thank you for taking the time to post this study
I do remember with the years I spent at Rover, just how fickle the K, M and T Series engine could be with regards to carbonising valves
It was often attributed to short journeys and low mileage vehicles and it was not unusual to see a cylinder head removed twice in 18 months where the vehicle covered little in terms of mileage (Oil consumption was also a contributing factor on older vehicles)
I remember a "fix" being issued by Rover entitled "Carbon busting valves" which were to be installed on such engines. Whilst it sounded dramatic, it turned out these valves were machined with a thinner stem on approach to the seat face.
This would simply allow for a larger growth of carbon deposits before ultimately the same symptoms appeared again (sticking valve) I am not sure if there was more to these "carbon busting valves" but from the outside it did feel like a hack!
It does look like you were onto cylinder 1 here topic23536.html and whilst it is nice to obtain more conclusive evidence, it does leave you with another conundrum (to fix or not fix)
Thank you again for posting, take care......Steve
wiki38andy wrote: ↑Sun Aug 18, 2024 5:36 pm What kind of pressure sensor is this? For the ones I have founds on any car(intake, exhaust, differential, low/high pressure fuel, turbo, brake vacuum, ..) the output signal voltage follows the pressure variation. If measured pressure rises, the voltage rises, and vice versa. For most of them, at atmospheric pressure, bias voltage is 0.5V, but can be 0.8V or 1. Have you tried to calibrate a pressure/voltage scale for this sensor? Did you use the same sensor and Venturi tube on both captures? What sensor did you use for INT pressure? Here you are a capture from 1.5DCI K9K engine. RED-injector 1, BLUE-exh, GREEN- int. Dead misfire on cyl 3 as injector faulty. EXH pressure drops as cyl 3 builds up vacuum due to lack of combustion.
Going back in time to the 1980s I used to rebuild engines when they failed in service like many others in the trade, with what appeared to be an exception to the norm, and that being I like knowing why things failed and what caused it! The major problem I've always found in the trade being that people can ask questions, but the person answering the question must be very clever! I found many that got their backs up because as engineers etc, I looked up to them, but it seemed they didn't have the correct training or experience, thus getting myself a bad name because I think differently than the average trader!Steve Smith wrote: ↑Fri Aug 16, 2024 11:17 am
