PicoScope 7 Automotive
Available for Windows, Mac, and Linux, the next evolution of our diagnostic scope software is now available.
Thank you, Steve, for such a comprehensive reply, and sorry for the delay: despite my preferences settings, I mustn’t have ticked the box in the topic to be notified of a reply in the topic.Steve Smith wrote: ↑Fri Aug 09, 2024 12:18 pmHello Martin, I hope you are well and thank you for the post
The burn voltage does look exceptionally noisy and given this was a cold engine we have several possibilities to consider
Could I ask, did the vehicle misfire or run unstable during the initial cold start (perhaps uneven combustion more than misfire?)
If so, does this smooth out within a minute or so?
My line of thinking here is the condition of the air/fuel mixture during cold start
If we assume air intake and fuel delivery to be correct (a huge assumption I know but our other 3-cylinders are fine and this is an SPI) then my thoughts turn to oil or coolant ingress into the combustion chamber (This will soon clear)
Have you noted any oil or coolant consumption?
The other more sinister concern is reduced compression due to sticking or poorly seated valves as carbon deposits can form on the valve stems and ultimately intrude up into the valve guide (Oh the joys and wonder of the K-Series engine)
Before diving in, would it be possible to remove the spark plugs and compare them all for colour, carbon deposits and gap (Keep cylinder 1 plug clearly marked)
We may find clues as to the mechanical integrity of the cylinder
Once we have put the mechanical possibilities to bed, we can focus on air and fuel mixture, inspect for air leakage and fuel trim values when hot (via OBD)
Next, we can look at the integrity of the HT system, and my thoughts turn to not only the plug, lead and routing but also the rotor arm if this is a K-Series with the distributor cap located on the camshaft?
A visual inspection of the cap may reveal issues around the terminal for cylinder 1 HT lead. A test you can do to evaluate rotor arm gap (whilst removing the combustion chamber variables) is to disconnect the HT lead from spark plug number 1 and short directly to ground
Crank and start the engine to obtain the voltage required to jump the rotor arm gap, which you can then compare with others (From memory, this used to be 5 kV)
It would be great to see if your burn voltage has revealed a mechanical symptom described above, but if so, I would not dwell to much if the symptom clears when warm. We have to cut your engine some slack based on age, usage patterns and characteristics.
Often, if the vehicle covers very few miles, a prolonged drive will perform wonders for niggling mechanical issues. Whilst there could well be a scientific explanation and may theories as to why, I would be happy to accept any improvement as a result.
I have heard of such road tests being called “An Italian Decoke” to which I am sure there are many interpretations
I hope some of this helps and the laptop/software issue is resolved
Take care……..Steve
