Renault Clio good Cam-Crankshaft waveform
ktl2019
Post by ktl2019 »
Hello
Need a good waveform from cam - crank from a Renault Clio 3 cyl. 898ccm, 66kW, H4B 408 engine, from 2016
Car has error P0011 Camshaft Position - Timing Over-Advanced or System Performance Bank 1
There are no other option without removing the chain to check if timing is OK.
Car runs terible and sometime goes off
Clio KW_NW.psdata
(6.93 MiB) Downloaded 1682 times
wiki38andy
Re: Renault Clio good Cam-Crankshaft waveform
Post by wiki38andy »
Most of times P0011 fault code is set for INT valve timing control solenoid performance outside expected range. So, remove and check VVT solenoid for sludge/deposit and free movement. Remove camshafts cover and check if the INT camshaft is locked in INT dephaser. If this camshaft moves freely back and forth, the dephaser is faulty. I would also flush the engine and replace oil+ filter. Then check oil supply to VVT solenoid and oil pressure. Could you post FFD when P0011 is set? When is the fault code set? At start, on idle or under the load? For crank-cam correlation(timing issue), ECM sets P0016.
It would be very useful in cylinder pressure waveform if you have a proper pressure transducer.
ktl2019
Post by ktl2019 »
Tanks for your answere
Have done an oil change and check the VVT solenoid, no sludge/deposit. But only 0,2 Ohm resistor.
But now i have the error 001178 CAMSHAFT PHASE CONTROLLER, camshaft shifter position error. After clearing the error and starting the engine, the error immediately returns.
When I activate the VVT ​​it clicks
But in diagnostic i have solenoid valve programming not performed, hopw can i perform this, do i need the original tester ?
wiki38andy
We need the FFD data when P0011 is set. Do you have any PWM signal from ECM to VVT actuator when starting and running at idle? Connect the oscilloscope to solenoid , CKP and CMP . Start the capture just before to crank the engine. Post the pasdata file. Test with VVT actuator disconnected. If fault code still there, remove the head cover and check if INT camshaft it is locked in dephaser and does not move freely.
ktl2019
Post by ktl2019 »
Have not saved the FFD with P0011 and this error does not come anymore.
Tried yesterday to save a caputure with the PWM signal, but yesterday i have on both lines 12V. Tought this is because the error are stored
In your picture, green ist the PVM from the VVT, and this is a waveform from the same engine? Then my timing is not right
wiki38andy
Green line is from ignition coil 1 control signal from ECM. It is normal to have 12V on both VVT actuator pins when ECM does not control it. You will have a zero volt line till ECM grounds one pin. Then you will see a 12V square waveform signal.Post the FFD data for the fault code you have now. Scope CKP, CMP and VVT signal from both actuator pins. Start the capture just before to crank the engine. In cylinder pressure waveform.
ktl2019
Post by ktl2019 »
When engine is running in odle, on VVT no PWM signal
But when i do a actuator test i have a PWM signal
When VVT is disconectet also no PWM signal at actuator test
FFD from errror 001178
Clio bei Stellglieddiagnose.pdf
(64.13 KiB) Downloaded 5984 times
Clio während er läuft.pdf
(73.69 KiB) Downloaded 5967 times
ktl2019
Post by ktl2019 »
Camshaft adjustment should be mechanically OK, but why does the control unit not send a PWM signal
Connected directly to batterie, see video
https://youtube.com/shorts/Xgeacv3ZiRo?feature=share
And here a waveform for cylinder pressure, have captured the first time this, so i do not have knowledge
Pusch Zylinderdruck 1 Zyl.psdata
1. cyl
(10.09 MiB) Downloaded 5968 times
Pusch Zylinderdruck 2 Zyl.psdata
2. cyl
(6.66 MiB) Downloaded 5959 times
With manual compression test i have13 bar, maybe my PDS500G is not right calibrated
wiki38andy
ECM does not send PWM signal when cranking and on idle. Just above the 1200-1500rpm and any time under the load. If you start and let the engine on idle, without any rev up, does the code P0011 set?
ktl2019
Post by ktl2019 »
No, the code P0011 does not come anymore
Now always the 001178 comes after few secounds with running eingine
Will measure again tomorrow with load from 1500 rpm
