Relative compression waveform - Subaru H6
estilley
Post by estilley »
I performed a relative compression test using my PicoScope 2204A with a Hantek high current clamp on my 2002 Subaru Legacy with the 3.0 H6 engine.
My peaks and troughs are all similar but I get weird double and triple humps (double on one bank, triple on the other).
Any idea what these could signify? I have attached a screenshot of the waveform.
Current car symptoms are a rough idle with no check engine light.
picowight
Re: Relative compression waveform - Subaru H6
Post by picowight »
Not sure about the double humps but 155A seems low to me. Synch a coil and see if it occurs at TDC and if you have 6 humps not 3!
