engine oscillating rotation failing
ademiltonxavier
Post by ademiltonxavier »
Good morning guys!
See if anyone with more experience can help me with these diagnoses here, I went to a machine that showed oscillation in the engine rotation, I did the engine relative compression tests ok, then I collected information from the injectors, crankshaft rotation, valve control, and I noticed a difference on one side of the injectors,
CHANNEL-TO-CRANKSHAFT
CHANNEL-B-VALVE COMMAND
CHANNEL-C-SUPPLY-1 INJECTORS
POWER CHANNEL-2 INJECTORS
And a significant difference in the injector drives, is this normal?
I couldn't attach the pico file or the video here, here's the link to the drive with both
https://drive.google.com/drive/folders/ ... drive_link
PaulW
Re: engine oscillating rotation failing
Post by PaulW »
I requested access to your gdrive to view the video and capture.
ademiltonxavier
I released it as soon as the notification arrived, sorry I thought it was free for anyone to cum with the link
