Diagnostico Guiado
leonardorj
Diagnostico Guiado
Post by leonardorj »
Bom dia a todos, esta nova funcionalidade de diagnostico guiado funciona em lingua portuguesa ?
Ou será apenas ingles ..
Re: Diagnostico Guiado
Firstly, I must apologies for not replying in Portuguese. I would use a translate program but I wouldn't know if it made a mistake or not!
The majority of the guided tests are available in Portuguese. When you change the language in PS7 it will update the guided tests at the same time.
Click More > Settings and then select the Language tab.
When you select another language you should see the text in PS7 change as well as the text in the guided test window. As mentioned, the majority have gone through the translation process but we have a few that are still waiting.
I hope this helps.
