2017 honda hrv 1.6 i-dtec
If you drive it at 1600 rpm for some time it will se a code p00bc mass airflow flow too low. Tested low and high pass egr it passed, did inspection of both egr valves and both are clean.Flashed ecu with latest software and no chainge. Tried another maf code came back. Recorder with pico 2 powers 5v and 12v and signa, and when signal drops from 2.7v at 1600rpm to 1.7v is sets a code for low flow. I checkes for recalls and tsbs and no luck so i need new ideas
