Pico 7 phase and graph rulers issue
VASTech
Post by VASTech »
Hello everyone!
I have found a little software issue regarding phase and graph rulers. Conditions to recreate the problem:
Set phase rulers 0 and 720 on the waveform, then add graph rulers to measure some timing. By changing the offset position of phase rulers, the delta degree of graph rulers should change aswell. It`s only change the value when you move the 0 degree phase ruler, if you change the 720 degree phase ruler, the delta does not update. Found this issue in 7.0.109.12623. Version 6.14.25.5247 does not have this issue. Hope this issue will be resolved soon! Thank you.
Re: Pico 7 phase and graph rulers issue
I have just confirmed this bug is apparent in PS7 EZ build 7.0.117 too
I will add a bug report for the software team to triage ASAP
Thank you again, take care.....Steve
VASTech
Post by VASTech »
Hello Steve!
In version 7.0.121.14753 EA this bug is still present! It must be very hard, or tricky to solve this issue :lol:
All the best!
Hello and thank you for the reminder
I have just checked the status and the bug I raised proved to be a duplicate
Checking the status of the original bug I can see it has been placed on "Backlog"
I have requested an update and will post ASAP
Take care.....Steve
VASTech
Post by VASTech »
EA 7.1.4.15470 :roll: what can I say! It seems that this issue is bother only me! However... maybe it`s only me that i`m using this feature and that` s why is not that important to fix. Hope that eventually will be fixed!
P.S. It is annoying!
Hi VASTech, thank you again for pushing on this one.
It will be resolved rest assured and sorry for the delay
Take care....Steve
Hi VASTech, thank you for your patience on this one.
This was resolved in build 7.1.5 and I have just verified in build 7.1.8 EA
Once again, thank you raising this one
Take care.....Steve
