I have changed the timing belt on a Peugeot 5008 with a 1.6 hdi 9hz engine
Now the car won't start. I am absolutely sure that the timing belt is installed correctly
I get an error code that there is a mismatch between the crank sensor and camshaft sensor.
It looks like there is a break in the reluxation ring at approx. 138 degrees
Could this be the reason the engine won't start?
