Hello, would like a reference for cam/crank on this vehicle, have fault p0365, with what appears to be chain rattle, so I do suspect tensioner/chain issue. I have taken my files with the intake cams/crank and exhaust cams/crank. I have searched alldata(US) and identifix(there is nothing on this vehicle there). here is the info to "pin out" , the pin locations on the ecm connector- connector f143 intake cams bank1 pin 26, bank2 pin 85, crank pin 31, exhaust cams are bank 1 pin 33, bank 2 pin 75, I can give picture of ecm pin out too. tear down to inspect is more than just a simple comparison of the cam/crank wave forms.
ok, please direct me to what to ask as i haven't seen this engine anywhere online, i have requested a cam/crank on multiple forums. i tried this yr, 3.0l v/6. does the other v/6 engines they have, have the same correlation?
joel
