Guided Tests
Joshasta
Guided Tests
Post by Joshasta »
Hey guys,
How do I exit the guided test mode and go back to regular measuring?
After I select a pre-set test, and I want to go back to manual measuring, what do I need to do?
I have been just closing the program to go back to normal measuring, but I am sure there must be a way to exit the guided test mode.
Hope that makes sense.
Thanks,
Joshasta
Re: Guided Tests
Post by Joshasta »
figured it out incase anyone reads.
you just have to select a new probe for the scales to change. pretty easy
not sure why that wasn't working for me yesterday....
Re: Guided Tests
Post by Technician »
I'm not sure 100% if this is correct or not without trying it on the scope but...
Select More from the left hand side menu and then look to find Reset configuration on the lower right hand side. Select it and the scope should reset I think!!
