Upgrade for new Waveform Library support
PicoBarney
Post by PicoBarney »
Hi all,
Further to our previous announcements and notifications regarding support for the Waveform Library within PicoScope 7 Automotive, we can confirm that we will switch over to a totally new platform on Thursday the 14th of July 2022. On and after this date, you will need to upgrade to a suitable version of PicoScope 7 Automotive to continue using it.
The new, totally redeveloped, PicoScope 7 Automotive waveform library has all the features of the old library as well as better search performance, and upload/download capabilities. We believe it is a significant step forward from the old library and hope it helps you to unlock your diagnostic problems even more quickly and easily.
Best regards,
Barney
Choppered&Whoppered
Re: Upgrade for new Waveform Library support
Post by Choppered&Whoppered »
Is there a primer that effectively might spell out the process for uploading a known-good waveform? I recently made a capture and would like to share it, but having never done this before, I don't know where to start.
Zsolt
Post by Zsolt »
Üdvözletem! Kérdésem az lenne hogyan tudnám letölteni a PicoScope 7 szoftvert úgy hogy teljesen alapértelmezett legyen? Mert az IDŐBÁZIS gombnál nekem a SCOPE felirat jelenik meg. Ezért szeretném törölni a szoftvert, és az én saját beállításaimat nélkül alapértelmezettként újra letölteni mert a frissítéssekkel sem oldódott meg a probléma eddig.
Köszönettel : Szalai Zsolt
Hello "Choppered&Whoppered " I hope you are well? Sorry for the delayed reply
The following video from Ben will guide you through the Reference Waveform Library (RWL) functionality
https://www.youtube.com/watch?v=M4YPL-zmZw4&t=1s
Moving on, please forgive my poor Hungarian language skills Zsolt and equally any misinterpretation of the question
Which versions of PS7 auto do you have installed at present? Stable, Early Access or both?
Could you provide the version numbers?
If you only have stable, then downloading Early Access will install as a completely new App with default settings (and vice-versa if you only have Early Access and install Stable)
Would it be possible to include a short video demonstrating the probelm you are experiencing?
You can use support@picotech.com if preferred
