PICO 7 crash when viewing saved forms
- OneWave
- Pico Staff Member
Re: PICO 7 crash when viewing saved forms
I am sorry to hear about the "crashing" you have experienced, could you help with the requests below?
Could you confirm the PicoScope 7 version you are using?
Could you confirm if the same symptom occurs with Early Access and Stable versions of PS7?
Could you confirm if the software generates a crash report or closes without warning? (No crash report generated)
If a crash report is generated has this been sent to Pico?
If so, could you estimate a time and date as we can locate this exact crash report
Can you reproduce this crash when reviewing the file above?
If the crash can be reproduced, could you provide a short video demonstrating the events leading up to the crash? (You can send this video to support@picotech.com)
I would like to try the offending file here at Pico, could you send the file into support@picotech.com reference this forum post?
Rest assured we will resolve this for you ASAP
Take care.......Steve
