WPS500X Using with snapon Compression adapters??
Mitchroberson
Post by Mitchroberson »
So I bought a WPS500X and want to use it with the snapon compression adapters. I do not want to have to spend more on new adapters. is there an adapter that works with these? I see 2 different adapters but not sure which one works.
Re: WPS500X Using with snapon Compression adapters??
Post by liviu2004 »
That’s probably a question for snapon?
Grant_Baker
Post by Grant_Baker »
I don't know what you mean by the phrase "Snap-On compression adapters." The Pico hose is the best.
https://www.aeswave.com/Foster-2-Series ... p9448.html
victor2k
Post by victor2k »
Please add some codes for your adapters,I think you need a Foster series 2 female to rectus 21 (or 26) female adapter.You can build one with these parts:
https://www.ebay.com/itm/Rectus-21-Typ- ... 1adce69dc8
https://www.picoauto.com/products/press ... h-npt-male
and a cooper washer.
Best regards
Mitchroberson
Thank you. I will give this a try.
