Zoom feature in cylinder balance test
jueja
Post by jueja »
I can not zoom into the signal graphs of the cylinder balance test. The zoom function does work in other tests, for example the compression check. Is this me doing something wrong or is it a bug?
Re: Zoom feature in cylinder balance test
This appears to be a bug as I have tried 3 versions of PD Cylinder Balance going back to 1.16.49
Right click or pinch zoom (via track pad) do not work for me
If you could the confirm the same for mouse wheels and touch screen that would be great
I will file a bug report now
Thank you for the heads up
Take care......Steve
jueja
Post by jueja »
Thank you for the reply Steve.
I do confirm the problem does exist on mouse operation as well as on touch screen.
jueja
Post by jueja »
So the zoom feature does work now with the latest beta version but....
I think it would be even more beneficial if it was possible to not only zoom into the signal graphs but then also being able to scroll through the entire capture while maintaining the zoom level. Could this be considered for a future update?
It works when mouse operated but not with touchscreen??
Thank you!
I have added your comments to an existing New Feature Request of a very similar nature
It is great to receive feedback from our customers as this provides additional weight when new features are triaged for development
Thank you again
