Toyota oxygen sensor not showing right?
Julius Nolin
Post by Julius Nolin »
Toyota Yars 2012 1NR-FE
I'm stuck with things I can not trust. Toyota oxygen sensor before and after catalytic converter shows unreasonable. I've read one there and can not remember what I did wrong. maybe some sharp person here who can help me.
blue is before cat and red is after. This is what I get. heated or not. There are zirconia sensors both before and after. but it was something special (check picture)
I also have a file from my measurement that I have added. I have not uploaded it to the library as I am very skeptical if I have done the right thing. feel free to provide feedback so maybe this can be resolved.
Toyota_Yaris_2012_Petrol_20220322-0001.psdata
(1.29 MiB) Downloaded 203 times
3
3
2
2
1
1
Re: Toyota oxygen sensor not showing right?
From air/fuel sensor you can measure -0.36 mA current at air -fuel ratio 13 ,0 mA at fuel-air ratio 14.7, ,0.36 mA at fuel-air ratio 17.7.This current is pumped by ECU in sensor circuit to keep voltage at 0.4 v between AF+ and AF-,better use a scan tool to read air/fuel ratio,even with K2 clampmeter you will have a lot of noise.
Best regards
o2 sensor vs af sensor.rar
(479.55 KiB) Downloaded 201 times
PicoKev
Post by PicoKev »
Julius Nolin
Thanks for the quick answers. it turns out that the more you know, the more you know you do not know. I study further :)
PicoKev
Post by PicoKev »
Julius,
In life in general and in this profession especially, the studying new stops. :)
leonardorj
Post by leonardorj »
As indicações para medir sondas A/F são via scanners para uma melhor conclusão.
