Pico 4423
Pico 4423
- Pico Staff Member
Re: Pico 4423
The test you are referring to is the Wiggle Test with our BNC+ resistance lead below:
This test does require the BNC+ scope and resistance lead here https://www.picoauto.com/products/test- ... -test-lead which is not applicable to your 4423.
This is not to say the 4423 is somehow redundant as this is a worlds class scope
For Wiggle Testing, you could choose to measure the signal or voltage present on a cable whilst wiggling and maneuvering connectors/wiring harness etc.
If graphing resistance with a 4423 is absolutely essential for your application , then could you take a look here viewtopic.php?p=100263#p100263
