Invert channel + invert trigger
jueja
Post by jueja »
May it be possible to invert the trigger setting automatically as well when inverting a channel´s trace? Thank you.
Re: Invert channel + invert trigger
Referring to the inversion of the trigger setting:
Could you give an example where this would be applied and to what style of trigger?
I have in my head a quick toggle option to switch from “Rising to Falling” for a Simple Edge Trigger
Would this be similar to your suggestion or do you have different in mind?
Take care……Steve
jueja
Post by jueja »
Thank you Steve for the reply.
I was thinking of an ampclamp signal or an secondary ignition pattern upside down/vice versa. When triggering on these and inverting the signal trace the stable pattern on the screen gets lost becasuse the trigger will stay "on the other side", be it positive or negative.
Thank you for the feedback and the clarification
As I now understand it, you would like the trigger to move with an inverted channel?
I.e., If triggering on channel A at +10 A and then you "invert" channel A, you would like the trigger to also invert to -10 A?
If this is correct I will add these conditions as a new feature request
Take care.......Steve
jueja
Post by jueja »
Yes, this is correct. Thank you once more!
