2007 honda accord value package 2.4L: can bus problems
JFP
Post by JFP »
Can-bus problemswith no comunication with master control switch and underdash fuse panel. It seems like its ground shorted. I look around all the wires and none of th them seem broken or cut. How can I test a short to ground and what tools do I need ,to do this test.
Re: 2007 honda accord value package 2.4L: can bus problems
Post by liviu2004 »
An ohmeter.
picowight
Post by picowight »
Disconnect the battery then use your meter on Ohms to check for continuity to ground on the can lines.
mikycar
Post by mikycar »
honda doesnt have ground problems check wiring where it comes from door into car maybe you have broken wire from door opening and closing or window master switch is bad
