Toyota Auris
Oscar Vence
Toyota Auris
Post by Oscar Vence »
Hi there.
I have a 2014 Toyota Auris, 1AD engine.
Does anyone have a CKP-CMP sync oscillogram?
Thank you.
Re: Toyota Auris
Post by liviu2004 »
Post your capture and then we check what is available.
Oscar Vence
Re: Toyota Auris
Thank you very much for the help.
Here is the capture of the vehicle in the starting process.
The engine does not start.
Toyota_Auris_2014_20211010-0001.psdata
(22.19 MiB) Downloaded 43 times
Re: Toyota Auris
Post by liviu2004 »
With a 4425A I assume you’ve checked in the library. Unfortunate nothing there. There is an Avensis 2008 with 1AD-FTV but cam signal is inductive.
I see a cylinder low on compression and one having more compression then others; unless start motor is almost gone.
Oscar Vence
Re: Toyota Auris
Yes, I have also noticed that.
But I distrust more that it is out of time, and that is why it does not start.
I'll check the draft of the distribution and if that's the problem.
I will make an oscillogram with the engine running to share in the library with you.
Thanks for the help.
victor2k
Re: Toyota Auris
Post by victor2k »
Your engine was disassembled?Why do you suspect the timing chain?Some parts was replaced?
If you can't find some good signals from CAM-CRANK you must check the engine compression,also the compression and injection (the main injection is at TDC at starting or a few degrees earlier).
If you don't have WPS or other pressure sensor you can capture battery voltage when starter is engaged and invert the signal
Best regards
victor2k
Re: Toyota Auris
Post by victor2k »
victor2k wrote:
Tue Oct 12, 2021 10:39 am
If you can't find some good signals from CAM-CRANK you must check the fuel rail pressure,also the compression and injection (the main injection is at TDC at starting or a few degrees earlier).
If you don't have WPS or other pressure sensor you can capture battery voltage when starter is engaged and invert the signalCapture.PNG
Best regards
Oscar Vence
Re: Toyota Auris
The car has stopped on the road.
It has little more than 30000km.
It only shows me the code P1604 startup failure.
I will continue investigating the case.
Thanks.
