Recommended K-type Thermocouple for dipstick temps?
DougS055
Post by DougS055 »
Hi All,
I just downloaded and installed the latest PS7 release and noticed a probe for temperature. Does Pico recommend a certain K-type thermocouple to use for checking oil dipstick tube temperature and comparing it to engine coolant temperature? If there is a different type of temperature probe to use with my Pico 3000 series 4 channel or 4823 8 channel scopes, which one would that be?
Thank you for your assistance,
Doug Saros
Everett, WA
Re: Recommended K-type Thermocouple for dipstick temps?
Hello Doug and thank you for the post
The Thermistor adaptor (or Temperature probe TA370) listed in the probe menu is not currently available to buy from Pico and therefore not a solution at present
It sounds like you are going to need a submersible K-Type Thermocouple and oil resistant at that.
Given you are using the 3000 and 4823 scope we are going to need a power supply of some form
Could you take a look here viewtopic.php?p=100685#p100685 at a similar request from another forum member who did find a solution using TMP35/36/37
Whilst we do not have an immediate solution at present we are working on a replacement for the TA370
Alternatively, a pre assembled battery powered transducer (E.g. 1 mV/Degree C/F) will support a submersible Thermocouple
