Had to abandon trying to use the EA today 7.0.78.8920, simple 0-5v signal, wanted 5s/div, set sample rate to buffer memory, it would start capturing once but when I tried to re-start I click Stopped, it flashed green then reverted to Stopped.
Just checked and it is repeatable: Can't find a logging setting but clicking Stopped on the below does nothing.
EDIT Apparently not latest version, did a manual update (set to automatic? ) and the new .8988 seems to have fixed it.
Thank you for sharing this.
My PS7 version 7.0.78 had exactly the same problem. It worked normally until I set 200ms/div where the streaming mode starts by default.
I was originally thinking the problem is with Windows or drivers on my laptop.
The new version 7.0.79 has fixed the problem and the streaming mode works fine now.
