Latest Win 10 Early access not working
picowight
Post by picowight »
Had to abandon trying to use the EA today 7.0.78.8920, simple 0-5v signal, wanted 5s/div, set sample rate to buffer memory, it would start capturing once but when I tried to re-start I click Stopped, it flashed green then reverted to Stopped.
Just checked and it is repeatable: Can't find a logging setting but clicking Stopped on the below does nothing.
EDIT Apparently not latest version, did a manual update (set to automatic? ) and the new .8988 seems to have fixed it.
Rfmotors1
Re: Latest Win 10 Early access not working
Post by Rfmotors1 »
Thank you for sharing this.
My PS7 version 7.0.78 had exactly the same problem. It worked normally until I set 200ms/div where the streaming mode starts by default.
I was originally thinking the problem is with Windows or drivers on my laptop.
The new version 7.0.79 has fixed the problem and the streaming mode works fine now.
scope7gilauto
Post by scope7gilauto »
Hi i have windows 10 pro ,with Dell touch screen
cant use zoom onthis version , works well on pico 6
Could you confirm the Early Access version you are using? Would this be 7.0.82?
Could you confirm our stable version has the same symptom? (7.0.80)
Could you confirm the zoom issue is a touch screen issue only?
I.e. can you add a remote mouse and zoom without any issues?
Take care.....Steve
