Fuel pump waveform
GlenODonnell
Fuel pump waveform
Post by GlenODonnell »
What can you tell me about this waveform?
Been doing some testing on the fuel pump on my Ford Falcon BA I6 2004 just to test out my new equipment, connected through the fuse using a loop wire and 60A clamp.
I am not sure what to make of the waveform, I believe it has 10 commutator segments but I could be wrong. Still new analysing waveforms.
The pump was not suspected to be bad, just tested it in my free time for educational reasons. :wink:
fuel pump1.pdf
(162.82 KiB) Downloaded 328 times
fuel pump.pdf
(155.12 KiB) Downloaded 271 times
Re: Fuel pump waveform
Post by liviu2004 »
If the pump is the only load on that fuse, then its on its way out.
GlenODonnell
thank you for the reply. :wink:
