BMW F21 N13B16A timing chain lengthened
ktl2019
Post by ktl2019 »
First, my english is not so good, i hope you understand me
Controll on a F21 1.6 N13 eninge the timing chain with tool 2 353 281. Result, chain is not OK.
So i controll it with PICO, but do not found the same in the libary, found a N13 waveform but it is different to mine.
Does someone have a waveform from the same engine ?
Channel A Crank
Channel B Inlet Cam
Channel C Outlet Cam
It´s definied in the channel infos, but in german
Koderle BMW 1er F21 KW_NW.psdata
(3.7 MiB) Downloaded 61 times
Re: BMW F21 N13B16A timing chain lengthened
Post by Technician »
Hi, I'm a little confused as to why you need a waveform now that you have eastablished that the chain is not okay. I'd now be renewing the chain kit and checking over anything that could be affected by the chain drive. Once you have the engine running correctly, you can then scope your own cam and crank and post those waveforms. :)
kona
Post by kona »
ktl2019
Post by ktl2019 »
Please can you send me the psdata, the picture are to small
