Hi i have problem with micra k12 1,2 the engine goes out after 30min, 1 or 2 hours sometimes it does not start. I send a signal when I do not want to work. the problem is with the crankshaft signal
I do not understand the symptom in your description. Either there is something lost in translation; or, grammar mistakes.
Since you are using a 2205A, you will need to reduce the amount of time on the screen until your sample interval is low enough to reproduce the signal accurately. Even with your insufficient sample interval for the given signal, I can see the abnormal CKP waveform shape is happening once per engine revolution.
The abnormal waveform shape is also happening in the CMP at nearly the same time; hard to tell with the given sample interval.
