2016 Audi A6 P0087
HillVS
2016 Audi A6 P0087
Post by HillVS »
I have a Audi A6 CHNA engine code.
It’s been with another garage and had the fuel filter and rail pressure sensor done.
The car flags the code when you ask for more throttle.
Rail pressure is whilst driving is consistently 200bar under desired. Idle it’s spot on. Supply to the pressure sensor is fine and doesn’t drop out the signal looks good again doesn’t drop out.
I believe this car has a inlet metering solenoid and want to test that but can this be done with a amp clamp to see if the valve is operating when being told to?
Thanks in advance
Mike.
JJW
Re: 2016 Audi A6 P0087
Post by JJW »
Hi Mike, unfortunately it is pretty much always the case that these low pressure issues are caused by mechanical damage on the pump sending swarf into other components (normally caused by a historic mis-fuel or years of poor quality fuel), usually starting with the pressure regulating valve on the end of the rail (it only takes a microscopic shard of swarf to keep this open slightly and prevent pressure reaching specification under load). Remove the valve from the HP pump carefully and check for swarf. Do not remove the valve from the rail unless you intend to replace it. There are checks that can be done with the PicoScope to check the HP system overall. Check Frank Masseys videos on youtube for DRV testing.
