I need some help for this transit.
I receive it after other car workshop.
They receive it after a stop on road. they control the timing chain ok change injectors change presure regulator, change ecu buy a new one from Ford. THE TRUCK NOT START;
I buy a pico to hop solve.
only one injector output have the good waveform on curant test with different injector ( i have 8 new)
i control synchro Ok
i control pressure regulateur output ok
i control pressure with manometer ok
No fault on diagnostic tool ( only pompe need adapted. need engine start to make it)
pressure regul out put
on the diagnostic tool the pressure consigm was 0
did some have an idear?
did some one know what the sensor who give to the computer the start order??
I hope find you capture. so i need to change the flywheel
Customer tel me he have a leak on cluth commande
i see it tomorow
Best regards
vincent
