Can i use old 4000 series channel a test leads to check battery positive cable voltage drop
FAROOQ_HUSSAIN
Post by FAROOQ_HUSSAIN »
With my old 4000 series which shares a commom ground for all 4 channels. By using channel A test leads to check battery positive cable voltage drop.does it shows potential difference in between the wire.is it must to connect one end of the test lead to ground.and please explain why is it important to connect one end to ground please explain as i am new to using picoscope.thank you for your valuable time to answer my question.
Re: Can i use old 4000 series channel a test leads to check battery positive cable voltage drop
Using a common ground scope to measure voltage drop in a supply line (i.e. anything other than a ground cable) will require the use of 2 channels referenced to chassis ground
The following article https://www.picoauto.com/library/traini ... ing-inputs describes how this technique is carried out using the 4423 (Common ground) and the 4425 (Floating input)
Basically, we measure the voltages at each end of the cable (referenced to chassis ground ) and subtract one from the other to find the voltage drop
I hope this helps and please feedback for any clarification
Take care...Steve
