Tablet based laptop
jr7305
Tablet based laptop
Post by jr7305 »
Any suggestions on a tablet based laptop to use with the pico scope? My thinking is to mount the scope on the tablet. Is there a minimum spec required? Rather not dump a ton on a tablet just figured it would be convenient. TIA
faraday
Re: Tablet based laptop
Post by faraday »
I use Panasaonic fz-g1 all work ok except markers (i can't reach them), I use picoscope 6 automotive.
jr7305
Post by jr7305 »
6 definitely not tablet friendly. Can’t pull them cursors in tablet mode.
picowight
Post by picowight »
I have 6 on a "convertible" laptop/tablet HP elite book. Works Ok except any attempt to zoom with touch just crashes it.
jibby365
Post by jibby365 »
Any update? I actually bought a surface RT and found it won’t run pico automotive software. Is there a tablet out there that will work or should I just give up and buy a tablet based scope?
The real win of a PC based Scope from a diagnostic perspective has to be the flexibility the operating system (e.g. Windows) presents to the user.
Whether that be extending the graph view to a larger screen, easy sharing of data (RWL) "screen grabbing" into other software suites (e.g. Power Point etc.) or indeed the ability to simultaneously run your scope with other Apps such as a scan tool or data logger (in a single view) as we have described here topic22669.html (the possibilities are endless)
Switching to an integrated tablet based scope will inhibit a number of the options described above and as technology marches on, who knows what benefits we can capitalize upon from the likes of Microsoft and Apple etc.
As for Specs for a Tablet Based laptop, we must consider Windows 10 a minimum (Win 11 is around the corner)
As many USB ports as you can handle ( USB 3.0 being a minimum for at least one, perhaps two for other peripherals)
64 bit is a minimum requirement for use with PS7A stable https://www.picoauto.com/downloads
Memory or graphics are not hyper essential but the more RAM the better
Storage is another factor unless you will be saving to cloud based storage
Multiple psdata files with high sample counts do add up over time
Here are the laptop specs I have been using for 2.5 years and it still remains seamless in operation with PicoScope whilst running other applications simultaneously
Image 1
Image 1
