2013 Nissan Pathfinder glow plug relay
Twins
Post by Twins »
Fault code for glow plug relay P0380
replaced glow plugs and relay (same fault)
checked wiring from ecu to relay (all ok)
It has a pwm signal to activate the relay & a return signal to the ecu. When i checked it with a good known i have found a problem with the return signal but don't know what is causing it. I have tried a 2nd hand ecu from donor vehicle but get the same signal.
Nissan_Pathfinder_Bad.psdata
(2.13 MiB) Downloaded 117 times
Nissan_Navara_Good.psdata
(1.85 MiB) Downloaded 128 times
